rear break-in, with new clutch also
im awaiting a mwc 9. no abs, posi, 3.89s. i also have a monster stage 3, cm flywheel, and new hydralics in my garage.
i know ill want to heat cycle the rear, and 500 easy miles, as for the clutch too.
will this clutch be too hard on that rear end to brake in? i know the monsters are a clutch that will grab, and be slightly rough for a while.
or is it better to leave what i have in it...break in the rear, and then put the clutch in?
15 heat cycles? eric at midwest in a post says 5 heat cycles. drive 15 minutes no wot, burn outs, being hard on it....etc. then cool for no less than an hour, then do it again. also not to go over 55mph.
then easy for 500 miles.
