Did i mess up my gears???
Old 06-03-2010, 06:46 PM
Outlaw72's Avatar
Your gears in that rear are shot. The pinion has made contact with the carrier and you can also see the damaged pinion teeth in the pics. That was most likely due to the pinion nut backing off.
Old 06-03-2010, 07:01 PM
Theblacknightls1's Avatar
Wow thanks outlaw just trying to prepare myself for what lethal is about to tell me in the morning.. So that rear would need new gears and stuff
Old 06-04-2010, 01:38 AM
Outlaw72's Avatar
The carrier is still probably good but you can clearly tell the pinion made contact with the carrier. The only way that would have happened is if the pinion nut backed off or the pinion actually snapped in half which doesn't seem to be the case since you were able to drive it.
I would say it needs a whole new rebuild but if you are on a tight budget, just a gearset and a good clean could get you back on the road. For how long....who knows?
Old 06-04-2010, 05:11 AM
Thanks for the info outlaw72.. Now i guess i just have to see how much they charge.
Old 06-06-2010, 12:43 AM
Loud02ss's Avatar
those gear mark engravings on the diff dont look right....unless im seeing things.
Old 06-06-2010, 11:10 PM
Outlaw72 was right had to rebuild rear.. I put 410s in it...well the shop did. I cant pick it up till wens so i need now to invest in some tires..
Old 06-07-2010, 12:08 AM
Black 99 Bird's Avatar
How much is that going to cost you?
Old 06-21-2010, 10:48 PM
Snake_Skinner's Avatar
Gotta love the 10 bolts with DR's!!! I put Nittto 555r's on my WS.6 and myy 10 bolt lasted less than 2 months before it crapped the first weekend i really went hard on it. My cars mostly stock too not even bolt-ons. Im with outlaw on the pics you can clearly see where the pinion scarred the hell out of the carrier, not good at all, i'd say def rebuild or jus say fu*k it and put a MWC fab 9" 35 spline axles\ w/ detroit locker in there. I jus bought a used rear for like $350 for now but will definitely be beefing up rear real soon if i even make it through this one.
Old 06-22-2010, 02:01 PM
Jawsgear's Avatar
I hope they changed out that carrier case too, because the pinion came loose and hit that carrier. When it does that you can get fractures in the case. Just my .02 but if you were here at our shop you would be getting a new positraction carrier as well, with all new bearings and a housing flush.
Jeff
Old 06-24-2010, 11:50 AM
JM0523's Avatar
Id rebuild it while your under there
