Moser 9 inch axle seal. Need help quick!!!
Well I just went to pull the car out of the garage and noticed a puddle of gear oil under the driver side tire. Long story short I pulled the brakes off and the axle seal is leaking.
What is a part number that I can use to pick one up that the autozone. I need to fix this ASAP.....
you can use regular axle seals. What I would do is to go to your local parts store, and tell them you need the seals for a 1975 Ford pick up with a nine inch. Same goes for bearings if you ever need them.
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
The axel bearing with the o ring is
9508B
RW508ERW
HIGH PERFORMANCE
WHEEL BEARING
GREEN BEARING CO
SUBSIDIARY of BEARING TECHNOLOGY
Johnny
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
9508B
RW508ERW
HIGH PERFORMANCE
WHEEL BEARING
GREEN BEARING CO
Johnny
