10 Bolt Rear??
As long as you can keep wheel hop away, and you don't let the diff run low on fluid, you'll be hard pressed to break the 10-bolt in an A4 car that's primarily street driven.
What bolt is missing? From the diff cover? Is the cover gasket leaking any fluid?
I Don't See Any Fluid Under There So I Guess I'm In The Clear For Now.
Sure, it's nice to have a 12-bolt even on an A4 car, but it's certainly not manditory for the auto. I'd just run the stock rear until you break it, which may never happen behind an A4 (even at heads/cam level) if you can keep wheel hop away.
If it's a bolt for the rear cover, i hope it isn't near the 6 o'clock position. At any rate, get a new bolt and drive it in there. If it was me, I'd change the fluid and gasket too while I'm under there.
i broke my rear with only having a lid and nittos lol. that one was warrantied though.
Thx for the Help Guys! I'm Going to Be Asking Alot More Questions As I Progress On The TA.
And im gonna agree.
Reason is don't fix nothing till its broke. My buddy is pushing around 550+ in his TA with the stock rear end (his is a M6) but my other friend with a SS (M6 as well) has yet to make a pass at the track with his 10 bolt. Some hold up well others do not. Im gonna say save up for the the new rear end then that way when it breaks you have the funds for a new one. besides if you do break the 10 bolt it only takes a couple hours to fix for the most part and around $50.00 in parts at least it dose for me and my buddy's (we got hook ups).
GL and remember it pays to play!
