9" Info
I have a Moser 9" with a Strange Center Section.
How much Gear Oil goes in it?
Where do you get Axle Seals cause mine is pissing fluid out the sides..
Thanks.
The Moser side has a very slight leak.
To see if the inner axle seal was bad on the NAPA side, I replaced it and it helped but still leaks. I have ordered 1 Moser bearing as the last hope to see if it helps. Oh and the vent is working fine.
Though I do not know if was due to having 4 qrts of oil. But when I pulled the passenger side axle there was about half an inch of oil in the axle tubes....
Napa Axle bearing part # 88128RA
Moser Bearing # MSR-9508B-1
Axle Seals or Inner axle seal for the Ford 9 # RAT-6128
I have a lot of information at this link that may help you out. Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
+1 Read it twice and did a Ctrl F. No luck here as well. I am seeing so many peeps with this axle leak issue.
So, dudes. What happens with long time exposer to oil being on my break pads? Will it catch fire? Make the pads shity?
