What do they weigh
Old Jun 27, 2010 | 06:04 AM
Mustang Hat'r 2's Avatar
Default What do they weigh
Sticky isnt working might as well put all the weight in here
10 bolt Stock 4 channel 10bolt wieghed inabout 155lbs dry
12 bolt Moser 12 both with 373 gears and 33 spline axles = 203 lbs
9 inch XXXXX missing 200
MWC 9 inch , Midwest 9 with 35 spline gun drilled/star flange axles and Moser 9 iron
center section spool. 175lbs
fab 9" is 172lbs with 4 channel and iorn center section 31 spline and posi.
fab 9" with Aluminum center section 33 spline gun drilled and spool it wieghs in at 150 lbs
S60 224 dry
Stole this from another thread
s60 weight something like 225 lbs and moser 9 inch weight something like 200 lbs. The stock 10 bolt weighed 150 lbs seems pretty close
Add to it if you know some
Jay
Old Jun 27, 2010 | 09:12 PM
chevynation's Avatar
^ Thanks, I was just searching for this
Old Jun 27, 2010 | 10:04 PM
35th SS's Avatar
thats about right on the 9in. with nodular iron and 31 spline axles.175lbs.running nodular iron on both of mine.moser and a currie with a strange center section.
Old Jun 28, 2010 | 03:12 AM
Snake_Skinner's Avatar
What about the Dana S60. I believe its 80lbs heavier than the stock 10 bolt right?
Old Jun 28, 2010 | 03:29 PM
If you find the answer post it and I'll add it. No time to look tonight, I know it ways the most.
Jay
Old Jul 1, 2010 | 10:12 PM
Rear Dry Weight Change from Stock this is from GMhightech article
GM 10-bolt 154.6 lb -
Strange S60 222.8 lb + 68.2 lb
Moser M9 205.6 lb + 51.0 lb
Old Jul 2, 2010 | 09:23 AM
01ssreda4's Avatar
Damn, that was a good thread. Wonder who would have deleted it?
