Rear end rebuild and now serious ring and pinion noise
What to do...just spent a grand on a rear rebuild minus new gears and now there's a noise in the rear caused by what the rebuild guy says is 'ring and pinion noise'. ??? Isn't that supposed to be part of the rebuild? I did just spend a grand to get it fixed. He says it needs to be adjusted. I'm not spending another dime to do this as a grand should have done the trick and should be part of the 'rebuild' i.e. new bearings,one new axle,etc. He didnt' replace any gears. I think I'm being taken, any opinions or help? Could sure use it about now....
The House is Rockin'
if they were not making noise before, they shouldnt be now.
sounds like a bad install, if set-up properly, gears shouldnt whine. altho there is the occasional set even when adjusted properly, while still whine.
a grand sounds alittle steep, did you put a locker? tru-trac in or something?
and DO NOT PAY him to re-adjust the gears, that was his job to get them right the first time. but knowing he already screwed up, it might be best to find a better installer.
