backlash
Old Jul 8, 2010 | 09:54 PM
DisturbedTA's Avatar
Default backlash
ok im instaling 410s in a 2002 transam 10bolt. i cant get the back lash down. its like at 5 .i know its too loose but i have no shims on the left and dont kno wat to do to lower it?no shims on the right side im sorry tired lol
Old Jul 8, 2010 | 09:58 PM
i was thinking maybe changing the shim on the pinion?
Old Jul 8, 2010 | 10:02 PM
bww3588's Avatar
whats wrong with .005? spec is .005 to .009
Old Jul 8, 2010 | 11:18 PM
i mean 5 out of ten on the gauge!
im sorry
Old Jul 8, 2010 | 11:20 PM
bww3588's Avatar
what the hell does that mean?
arent you using a dial indicator?
Old Jul 8, 2010 | 11:21 PM
bww3588's Avatar
Old Jul 8, 2010 | 11:35 PM
yes it has one to ten on it it supose to be between 0 and 1
is that not coreect?
Old Jul 9, 2010 | 12:40 AM
bww3588's Avatar
your not using plastigauge are you?
Old Jul 9, 2010 | 12:07 PM
no im not i did switch from a torsen to a aurban center chunck
Old Jul 9, 2010 | 12:54 PM
bww3588's Avatar
i still dont know what your using to measure backlash. a picture maybe?
Old Jul 10, 2010 | 02:16 PM
Mustang Hat'r 2's Avatar
http://www.advic.co.th/Images1/TECLO...0Indicator.jpg Look there where are you seeing 5 between 1 and 0?
If you are check gear recomendation that might be too tight. If your pinion depth is off it will screw the back lash up.
What pinion shim are you using?
Old Jul 13, 2010 | 11:09 AM
Jawsgear's Avatar
This makes no sense. You say you have 5, but 5 of what? and you also say you have no shim on one side? Sounds like the wrong carrier to me.
Jeff
