What is stock backlash? What are other things to check?
I checked my drive shaft and there was no play. So right no u joints are out of the question.
I am still looking for the shims.
I am ready to buy them from dealer but I faced the following problem:
When I was taking out my differential all that came out was
1-differential
2-bearing conical races
2-shims (.2425 & .2400 thick)
However in the parts manual when checking correct part # I noticed the assembly is as follows (page 862)
1-differential
2-bearings (including conical races)
2-spacers (.171-.172 thick)
2-shims (different sizes)
I double checked there was nothing left in the differential housing and nothing rolled away from me.
Does this mean that from factory they come with shims/spacers and when rebuilding I need shims+spacers????
Thanks all
1-differential
1-differential
Thanks all
I have finished rebuild, but it did not solve all the problems.
With a shim kit I set my backlash to .0055. I tired all shim combination I could think of and the best choices was .0100 and .0055, so I chose the second one. This exercise helped but did not get rid of all the problems.
Overall the clunking reduced, but I still have it; when cruising and applying gas on/off. There is reduced noise and no vibration during left turns and left tuns + breaking.
The new problem I have is: I get one clunk during right turn highway ramps and I started a new thread.
https://ls1tech.com/forums/gears-axl...l#post13901409
Thanks all.
Thanks all.
