12 bolt posi from a 98 camaro
I plan to pick up a 12 bolt, shorten it with custom axles but I was wondering if anyone knows these 12 bolts from the camaro's before I picked it up. Gears are unknown and I just wanted to make sure if it was worth shortening or should I look at another 12 bolt.
Thanks
Thanks
no 98 camaro had a stock 12 bolt, so you are likely buying either a 10 bolt or an aftermarket 12 bolt.
If you are not looking to put the 12 bolt into a torque arm car, you will be better off buying the axle if it is cheap enough and selling it on this forum for a 4th gen car, and then buying a different 12 bolt to build up. New they go for over 2000+, used should be at least 1200+
Ryan
Ryan
Ryan
Ryan
Ryan
Ryan
Ryan
Ryan
thanks
I actually going to put one in my colorado and it has leafs. Not exactly sure how but either that or a 9". Not sure what you meant by buying an axle and selling it on the forum. I assume you meant to buy my custom axles and us those in my shorten 12 bolt? So if this so called 12 bolt from this 98 camaro is a 12 bolt how can I tell other than 12 bolts? The guys said it has a posi so and the price is pretty cheap so I figure its worth a look.
thanks
thanks
Thanks for the info...so in my case what 12 bolt should I be looking for? I was actually planning on using my axle tubes from my colorado and attaching that to the 12 bolt along with new axles. What you guys think? Or narrow the original 12 bolt.
