Runnin' a spool
Old Oct 6, 2010 | 06:18 AM
ladybird's Avatar
Cool Runnin' a spool
Who here runs a spool in the street. Opinions?Love/hate? Is it streetable? My car only gets driven about 1000-2000 miles a year now. Just trying to decide if a spool will work for me.
Old Oct 6, 2010 | 08:00 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
If your driving is mostly rural and highway like mine is, the only time you'll really notice you have a spool is when turning in intersections. I've never had a problem in the rain either, you just have to be a little more cautious. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Oct 6, 2010 | 08:23 AM
Wicked94Z's Avatar
perfectly streetable, just kinda a pita to park.
Old Oct 6, 2010 | 08:45 AM
01SS99red's Avatar
its hard on the tires when parking and turning corners on dr's or street tires. As long at you dont mind a little wheel hop you'll be fine.
Old Oct 6, 2010 | 12:53 PM
straightleg's Avatar
I'm interested in the same question as originally posted.
so a spool on the street with the ocasional corner, will damage tires not break axles, thats ok with me
Old Oct 6, 2010 | 05:50 PM
01SS99red's Avatar
It wont damage tires if you take it easy around corners. And no it wont break your axles.
Old Oct 6, 2010 | 06:09 PM
Wicked94Z's Avatar
tight corners are hard on your axle bearings... just try to take turns as wide as possible
Old Oct 7, 2010 | 04:58 AM
LS1Tech Sponsor
We put a spool in a 864 rwhp CTS-V we built at the old shop several years ago, the customer has put quite a few miles on it without any problems. Bob
__________________
Old Oct 7, 2010 | 05:36 AM
93camaro_zzz's Avatar
But why a spool for the street? Wouldnt a locker be better in every way?
Old Oct 7, 2010 | 05:47 AM
LS1Tech Sponsor
Lockers can be a real hassle on the street as they don't always unlock each axle at the exact same time. This can cause the back of the car to wander around. The first time I ever experienced this, I stopped the car and got out and made sure the rear was still bolted into the car. Lockers have more backlash too, meaning you can twist the driveshaft back and forth about half a turn. This can cause manual transmissions to grind going when changing gears at part throttle. Bob
__________________
Old Oct 7, 2010 | 05:51 AM
twinturbo496's Avatar
Lockers:
Significantly more expensive.
More moving parts
Heavier
The tire wear issue is insignificant, most people who put in a spool are going to be doing other things that are much harder on tires than turning with a spool.
One real issue, if you have to push your car around by hand, out on to the street, staging lanes at the track, into the garage... you will only be able to push straight ahead or back, even with two people pushing, slicks make it even harder.
Old Oct 7, 2010 | 06:18 AM
romansz28's Avatar
I daily drive a car with one. The main problem I have is tires if u plan on having drag radials. Plan on buying new ones every month. Without ever spinning the tires mine lasted a month and a half. Mickeys that is. So I just put regular street tires on. Lasted about 5 months. They just wear right down the middle. And to be honest the uturns drive me nuts lol. But seeig as u only drive it 1-2k miles should be just fine
Old Oct 7, 2010 | 07:45 AM
CRAZZ28's Avatar
Slicks make it easier actually. most people who are running slicks have 15" wheels and at least a 28" tire theres alot of give in the sidewalls of slicks as compared to a 17" wheel with at 24-26" tall tire. Not sure where u got that info but one person can push a 2600 lb drag car with a spool and 34" slicks around corners in and out of the shop no problem.
Old Dec 12, 2010 | 11:50 AM
sschoeffler's Avatar
I'd like to know where you got your info because I have a full spool, 3.89 gears, 325/50/15 Nitto Drag Radials, which is a 28" tall tire and pushing the car while trying to turn is impossible. I have an assload of sidewall on my tires and they do not absorb the shock when making a turn it still pops louder than hell, I swear I am going to leave the rear end behind me somewhere when making a corner.
Old Dec 12, 2010 | 01:36 PM
223HAWK's Avatar
I daily drove my car over the summer with a Spool and 325/50 Radials..Only down fall is tight turns are tough. Other than that all positives..Lighter,stronger, less parts, cheaper..
Old Dec 12, 2010 | 02:40 PM
ls1curt's Avatar
i run a spool and have no problems with it at all. with my street tires or slicks, its hardly noticable on the street
Old Dec 12, 2010 | 05:15 PM
Blue85350's Avatar
i also daily a spool, minimal burnouts and what not my tires have lasted 11 months and need to be replaced pretty bad. all in all not bad, and i'd recommend it
Old Dec 13, 2010 | 04:47 AM
trans am 98's Avatar
If your a track car full spool is for you you stay on the street mini spool is the way to go I have my 9" with 4:30 gears and mini spool and its not bad at all but either is still fine trust me you'll like it
Old Dec 13, 2010 | 11:21 AM
BlackScreaminMachine's Avatar
Internet Mechanic
No spool here yet, but on my 12 Bolt from Moser, I have a messed up Tru-Crap diff that is locked and had been acting like a Spool for a few years. Aside from Excessive tire wear, I have had no issues.
Other then its a PITA to push and turning at the same time, if I could not drive it.
Old Dec 13, 2010 | 12:29 PM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
Keep in mind a spool can play havoc on your traction control.
In my own personal car a spool is the only choice, for the same reasons many have posted. You buy it and your done, no concerns with it breaking or going bad. Do a full spool though do not do a mini spool, mini spools have been known to break. Of course anything can break under extreme conditions.
I do not recommend a spool to everyone though and there is alternative choices out there that can be chosen based off your own personal needs.
