5 year long vibration
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Below is from BMR's website. Bob
Set the pinion angle using the following method:
Load the rear axle by either setting the car on the ground or letting the car rest on jack stands positioned under the rear axle.
Place the angle finder on the driveshaft and record the angle. The driveshaft angle is negative if it slopes downward towards the rear of the car. The driveshaft angle is positive if it slopes upward towards the rear of the car.
Now place the angle finder on the rear end torque arm mounting plate and record the angle. The rear end angle is negative if it slopes downward towards the front of the car. The rear end angle is positive if it slopes upward towards the front of the car.
Add the two measurements. This is your pinion angle. (Example: -2 rear end angle plus -1 driveshaft angle = -3 degrees)
Turn adjuster to achieve the desired angle.
As a starting point, most F-Bodies seem to like the following initial settings: Automatics: 1-2 degrees negative Manuals: 2-3 degrees negative
Please refer to www.bmrfabrication.com to view the video for setting the pinion angle.
Ok one of the reasons i refer people to use there local driveline shops is shipping...
These shipping companies like to throw things.... It is not fun hearing a customer with a shaft that has a slight vibe at __ mph because retards at shipping companies like to throw things..
I know everyone thinks a shaft is just a tube and joints.... yeah well throwing them around is not good for them and can change the balance....
Changing the joints CAN and DOES change the balance.
If you have a 4 at the pin and 2 at the shaft you have 2 diff, thats good
