axle lengths
Old 10-17-2010, 11:31 AM
southpaw0314's Avatar
Default axle lengths
im building a 8.8 from an explorer, since it has an offset pinion how would i correctly measure the axle lengths that i need?
thanks adam
Old 10-17-2010, 08:09 PM
Carl at CRP's Avatar
If You have the rear end dis-assembled, have a helper hold a straight edge on the housing end while You measure from the straight edge to the pinion center, repeat on the other side.
If You are not narrowing the housing most axle manufacturers have the dimensions for a stock length housing.
Hope this helps,
Carl
Old 10-18-2010, 04:16 PM
bump!
Old 10-18-2010, 07:22 PM
Apparently I didn't understand Your question. Could You let me know what I didn't answer that You need to know. I work with this on a daily basis and am capable of helping.
Carl
Old 10-18-2010, 08:29 PM
kickin wing's Avatar
Stock 4th gen camaro length is 32" Here is a list of different axle lengths that came in ford 8.8 rear ends.
http://www.kabele.com/pdf/3-Page-Axle-Shafts-WEB-AD.pdf
