por-15 rear, who's done it?
Old 10-25-2010, 09:24 PM
z28_theantirice's Avatar
Default por-15 rear, who's done it?
I have an S60 going to be here probably in a week or so. I am thinking I am going to use POR-15 on it, wondering how much I need to do a rear?
Old 10-25-2010, 09:58 PM
FirstYrLS1Z's Avatar
not familiar with S60s',stock 10 bolt I do with about 4 fl.oz.per coat. the stuff is thin and spreads/flows well.
Old 10-26-2010, 03:58 PM
ss1
ss1's Avatar
I just did my 12 bolt a couple of weeks ago. A pint should be more than enough to do two good coats. Just be sure that you put some saran wrap in the can between coats to keep the remaining POR15 from hardening. Best bet is to dump what you're going to use into a container and take care of the rest right away. You want to keep as much air away from the POR15 as possible because it will go to waste overnight if not properly stored.
Old 10-26-2010, 05:22 PM
How much time is needed between coats?
Old 10-26-2010, 05:40 PM
trik396's Avatar
and do yourself a favor and make sure to wear gloves. If you get that stuff on your skin only time will remove it... seriously...
ask me how I know.
Old 10-26-2010, 07:04 PM
LPE 403's Avatar
^ +1 for sure...that stuff is crazy!! Bullet proof when done though
