Lt1 to Ls1 Ford 9"
Lt1 to Ls1 Ford 9"
I have a ford 9" that i ran in my lt1 and took it out befor i sold it. I picked up an ls1 and i wanna put it in but im not sure what all needs to be changed. Do i only have to change the backing plates for it to fit? What about the drive shaft? What else is different that i might need to change on it?
Backing plates (unless you want to run LT1 brakes) and possibly ABS stuff if you are going from a 3 channel car to a 4 channel.
DS and everything else should be fine, if both were manuals...not sure if one was a manual and the other is an auto.
