Axle Seal
Old Dec 18, 2010 | 03:59 PM
the_merv's Avatar
Default Axle Seal
Anyone have the part number for the Axle Seal to fit the Moser Fbody 9" Housing?
It's the seal that goes in the endcaps.
It used to be in a sticky here..
Old Dec 19, 2010 | 11:39 AM
SS SLP2's Avatar
you can use regular axle seals. What I would do is to go to your local parts store, and tell them you need the seals for a 1975 Ford pick up with a nine inch. Same goes for bearings if you ever need them.
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
The axel bearing with the o ring is
9508B
RW508ERW
HIGH PERFORMANCE
WHEEL BEARING
GREEN BEARING CO
SUBSIDIARY of BEARING TECHNOLOGY
Johnny
__________________
Old Dec 20, 2010 | 12:48 AM
the_merv's Avatar
Thanks bud..
