Valvoline 75W90 Limited Slip Oil
Just bought a few bottles of Valvoline Synthetic gear oil and it says for limited slip on it, on the back it says the same. I couldn't find limited slip additive to buy just in case, is this oil good or do I still need the GM additive too? Oh and I bought Gray RTV , is that good?
I was using the gasket supplied with my TA girdle and RTV for added piece of mind. I've heard too much about these things leaking after being taken somewhere to be done or leaking after the DIY job without sealant. I believe you, but why do so many people have trouble getting it leak free?
The oil is fine. You shouldn't need any additive. As for the cover seal. I always buy a gasket, lay a thin smear of Ultra Black Permatex on both sides and tighten cross-wise, like you would lug nuts. That along with clean mating surfaces and it will never leak a drop. Go back and resnug the bolts after 1 hour.
