Pinion seal
Old Jan 6, 2011 | 01:40 PM
SINCWS6's Avatar
Default Pinion seal
So i'm pretty sure my pinion seal is leaking and i need to replace it. Is there a write up anywhere on how to do it cuz its one thing i've never done before. Also is it alright to drive it a little i check the gear oil and it still has plenty?
Old Jan 6, 2011 | 03:04 PM
01ssreda4's Avatar
Typically they leak pretty slow. As long as you are keeping tabs on the fluid level you should be fine to run it. You dont want it running dry though. Search around, there are tons of threads that have helpful links in them for disassembly.
