Yet Another "Analyze This Pattern" Thread - Ring and Pinion Change
Old Jan 25, 2011 | 11:13 AM
Silver02Z28's Avatar
Default Yet Another "Analyze This Pattern" Thread - Ring and Pinion Change
I installed a new (slightly used) carrier with a new 4.10 ring and pinion set into my '02 Z28. The stock carrier shims were too tight, so I used the shims from the ring and pinion set.
I might need to open the backlash a bit, it was not quite .006", but before I do that, I'd like to see what the experts think about this pattern.
It looks OK on the drive side, but moves toward the toe on the coast side.
Drive
Coast
Thank you for your input.
Old Jan 25, 2011 | 12:04 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
agree,the drive side looks good.
from a GM tech manual.
