3rd Gen rear in my 4th Gen
Fwiw I have a '93 auto, stock stall, stock gears, bone stock. I do not, nor do I ever plan to race. I have no desire and my car has not been north of 4k rpm since I bought it.
That said, I'm picking up a non-posi 3rd Gen rear for practically free. My plan is to use the narrower rear with some super low offset, deep dish wheels.
Will my 4th Gen posi, gears, brakes, etc swap over? I don't have traction control and will be deleting abs. And, I will let a professional do the swap/install with all new seals, bearings, shims, etc. I plan to keep a pair of 2in adapter/spacers on hand in case I want to use my factory wheels or spare.
Is this doable and what should I look out for?
yes it will fit. yes no abs. the rear is narrower by about 1.5 or so on each end. 4th gen brakes will bolt right up. the early thirdgens had 26 spline the later years were 28
the thirdgen also had a Borg Warner "9 bolt" it was a 7.75" ring gear and is stronger than the 10bolt by a fair amount most are worn enough by now that you wont notice any improvement in strength with out properly going through the posi and bearings
or if your lucky some got the GMPP dana 44
I dont mind if its not any stronger, it'll give me some hands-on experience with rear ends and allow me to run lower offset wheels
got the rear - in my garage on stands now. its out of a '91 V6 firebird
any idea what # spline axles this should have? AFAIK its bone stock internally. I'm guessing my '93 has 28 spline axles? my plan is to move my posi and gears over to use with the 3rd gen rear
ALSO, it has the Delco calipers with new pads and very good discs... any idea what that setup is worth since I'll be moving my LT1 brakes over??
TIA
TIA
TIA
TIA
I think those rear are very strong for a 7.75" ring gear! its the same rear as the TTA its also what I was using on my ls1 t56 car and MT slicks at the track it took the abuse but I knew it was on borrowed time. do they break hell yeah but for such a small gear its one tough little guy and its setup very nice looks like a small dana, no c-clip junk and 4 pinion posi
For the brakes IDK I would look on TGO if its a 91 3.1 rear it should be 28 spline but I thought drum brakes.... 88 1/2 -up got the PBR calipers I'm thinking you will have to open it up and see what is really in that one
the brakes are different though - the previous owner of the rear took off the drums and converted to a complete Delco disc brake system
the guts from your 93 will work
