8.8 build pics with a tq arm mount
8.8 Build is out of a fox body Mustang. I am running stock length for the Mustang and going to run Mustang rear disc brakes. I have everything welded on and have it test fitted besides the TA. The rear end is out at the machine shop getting the TA mount fabbed up.
Question is..... Is anyone running both a TQ arm and mini ladder bar setup? I would like this in there as added security.
[QUOTE=MUSTANGBRKR02;14411645]2"s narrowed per side. I am going with a 35 spline full spool and cclip eliminators for a stock length 94-98 Mustang with no ABS.
With 2" narrower the 10 bracket fit in the 8.8 axel tubes giving you space for the rear brakes?
You use the 8.8 axel tubes rigth?
Most of it did not need to be preheated, but some of it did and the spotlight did the trick. I could not touch it without burning my hand and there was/is no cracking between the two metals and I have penetration into the pumpkin.
I hope not lol. I am looking at some more options also. It's just a temporary build until the MWC 9" can be bought for it.
did you test fit the TA mount? Mine came out of 86 mustang, and without griding down the 8.8 and putting the TA mount RIGHT up against the rear it wasn't going to fit in the tunnel, but I have seem some rangers with more room on the driver side for the ta mount to be offset like that
