Rear end questions
Old Feb 17, 2011 | 02:21 AM
kalildude's Avatar
Default Rear end questions
How do I know what chanel my rear end is?
Old Feb 17, 2011 | 05:37 AM
lt1 sport's Avatar
If your car has traction control (ASR button) it's 4 channel.
No traction control=3 channel.
Old Feb 17, 2011 | 06:57 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Correct,
Also IF your looking at a 10 bolt out of the car, lets say a junk yard, the sensor on the top off the pumpkin is for the 3 Channel ABS w/o TCS/ASR, and if the rear end has exciter rings on the axle ends and sensors as well thats the 4 Channel ABS that will work with TCS/ASR.
Old Feb 17, 2011 | 11:29 AM
kalildude's Avatar
So it basicly doesnt matter what gears you buy as long as they are for a ten bolt?
Old Feb 17, 2011 | 12:33 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Depends on what series the carrier is, either 2 or 3 series
2.73s - 2 series
3.23/3.42s - 3 series
Old Feb 17, 2011 | 12:53 PM
Internet Mechanic
Yes It does, see z28/2002's answer.
IF your not sure of the ratio, you can use the Chalk method and measure the ratio of turns with a wheel vs driveshaft.
Old Feb 17, 2011 | 12:55 PM
bigairboarder44's Avatar
I'm confused about my rear end... I have TCS but the sensor is ontop of the pumpkin. 3 or 4 channel? I swapped a 4 channel rear end from a T/A in (has wheel sensors), but my TCS/ABS is going crazy and turns off after a few minutes of driving. What's the deal?
Sorry for the hijack...
Old Feb 17, 2011 | 06:14 PM
kalildude's Avatar
Why the different series if they are all 10 bolts
Old Feb 17, 2011 | 06:23 PM
Z28/2002's Avatar
If you have a 2 series you'll need "thick" gears. The ring gear on the 2.73s are thicker than the 3.23s and 3.42s hence why you would need the thicker gears.
Old Feb 17, 2011 | 07:20 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
a 'series' defines the distance between the centerline of the pinion gear to the carriers' flange surface where the ring gear bolts to.
for 2.73s' and 3.08s',where the pinion gear is larger than the others,the ring gear is required to be farther away from the pinion centerline.
if/when you're using a 2 series carrier and want to use 3.23,3.42,3.73,4.10 gear,they have to be of the 'thick' design.
Old Feb 17, 2011 | 07:32 PM
garygnu's Avatar
you can buy 3 series ratios that work on a 2 series carrier.
Old Feb 17, 2011 | 09:24 PM
kalildude's Avatar
How do I tell what series I have without taking it apart and measuring it?
Old Feb 17, 2011 | 10:38 PM
If your gears are 3.08 or lower, it's a 2-series. 3.23 and up is 3-series.
