Mini Ladder Bar set up??
Old Feb 22, 2011 | 01:07 AM
Mangum's Avatar
Default Mini Ladder Bar set up??
How many people have ran the mini ladder bar set up in the f body's? The ones who have did it cause hooking problems on the street??
Old Feb 22, 2011 | 04:18 AM
Turnin20s's Avatar
Do a search, its been talked about alot. Generally not the best option IMHO, or others opinion for that matter
Old Feb 23, 2011 | 11:20 PM
96lt1m6's Avatar
I did it. The car launched like an old Mopar! The car would try to bite hard but it would bounce. Absolutely the WRONG SET UP for these cars!
It ruins a perfectly good double duty car, normal driving is altered. Cornering makes me feel like I am driving an old Mustang it sucks! I did it to make my 8.8 install easier and inexpensive and all I got in the end was a nice set of upper arms to sit on my shelf of experience.
Granted not everyone will agree with my post but this mod changes the entire geometry of the f- body and ruins the overall handling of a near perfect car! Back to the drawing board for me its TQ arm time again!
Old Feb 24, 2011 | 02:44 AM
Turnin20s's Avatar
Thats pretty much the info I came up with after alot of research. But I decided to give a 4 link a try, it will basically be setup like a SN95 mustang. But I have no idea how it will work, but everything is going to be adjustable so I can try a few different setups before I scrap the idea. Only one way to find out IMHO, and I don't see it done much so I figured what the hell
Old Feb 24, 2011 | 04:48 AM
96lt1m6's Avatar
The problem I see with what you are wanting to do is, the upper control arm eyes have to be cut off or you will hit the fuel tank. Now if you remove the tank you may have enough room to have an upper arm mount and proper travel.
Old Feb 24, 2011 | 12:54 PM
Turnin20s's Avatar
I have the ears cut off and have brackets for the upper bars that mount them a little lower, but hitting the tank worries me a little, but only time will tell.
Old Feb 24, 2011 | 06:44 PM
Mangum's Avatar
Dang well after some of this stuff I believe ill try to get the trq arm put in... Didnt figure it would be that much!! Some of the other forums said that the only thing they seen wrong with it is the wheelie's it causes....
Old Feb 24, 2011 | 11:53 PM
wfritts911's Avatar
I have the ladder bar setup and it doesnt drive bad at all. It might not handle the best but I dont expect it to. It anti-squats really bad but I think some decent rear shocks could control it somewhat. Its not terrible like some think and is pretty cheap and a lot easier than a torque arm mount. If I were you I would try it and if you dont like it you can switch to a torque arm later.
-Will
Old Feb 25, 2011 | 03:12 AM
Cronic_Moronic's Avatar
From what I have seen of most mini ladder bar setups they don't appear to have been setup with a ton of thought or understanding so it makes sense that people are having tons of issues with them.
Old Feb 25, 2011 | 10:37 AM
MUSTANGBRKR02's Avatar
There is Alot more that goes into getting the car to hang the front hoops then ladder bars.
Old Mar 11, 2011 | 03:57 AM
fastsspr's Avatar
HHHmmmm i have my 8.8 finished except the mini ladders bars but now i don't know if want them!!!
Old Nov 25, 2013 | 02:47 AM
AINT SKEERED's Avatar
How about adding these along with a Tq arm?
Seems it would limit the anti squat and also works like Pete z bars that hooked really well.
I'm gonna try it with some calvert racing 9 way adj shocks to control seperation
Old Nov 25, 2013 | 01:26 PM
97Z28SS's Avatar
I just got another 4th gen and a Exploder 8.8 rear to mod and I order one of Hiltsy855's torque arm mounts and I' going to use the Raceraft brackets for mine.
Old Nov 25, 2013 | 08:33 PM
cantfind2nd's Avatar
You see my build 97Z28SS ?
