MWC 9'' Clearance issue
Old Feb 22, 2011 | 09:16 AM
chon79's Avatar
Default MWC 9'' Clearance issue
Lately I've been hearing some banging underneath the car when driving. Only have 70 miles on the new rear end. I jacked it up with the suspension loaded and found that my Torque arm is touching right against the driveshaft tunnel. and is hitting it. Look at pics below. You can sort of see the rub marks.
My car is only lowered on BMR springs. Should I not have the torque arm on the top hole on this pic below for the trans mount?
Old Feb 22, 2011 | 09:21 AM
TransWS6Am's Avatar
I think they recommend the second hole from the bottom on a lowered car, seeing how it works out, and adjusting from there.
Old Feb 22, 2011 | 09:27 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
^^^ true dat
with the car lowered you will need to use one of the bottom holes in the pivot link.
Old Feb 22, 2011 | 09:38 AM
chon79's Avatar
Thanks Eric! I will switch it to the second hole from the bottom?
Old Feb 22, 2011 | 01:07 PM
MidwestChassis's Avatar
Yes second hole from the bottom will fix your issue. Any questions please let us know.
Old Feb 22, 2011 | 01:36 PM
chon79's Avatar
Thanks guys.
I also called Wavetrac like you recommended to find out what oil they prefer to use after break-in and they recommended 75/90 synthetic, as long as it isn't redline
Old Feb 23, 2011 | 01:08 PM
kc533's Avatar
Originally Posted by ssvert99
^^^ true dat
Haha amen, found that out the hard way after I lowered mine.
Old Feb 24, 2011 | 09:13 AM
chon79's Avatar
lol did you have the same problem with torque arm banging?
