trying to order gears need help!!!!!
This is Motive's standard replacement set (blue box):
http://www.summitracing.com/parts/MGR-GM75-410/
This is their performance set (orange box):
http://www.summitracing.com/parts/MGR-G875410/
Hi,01redssa4 is correct series 3 carrier......make sure the kit is complete with crush sleeve/bearings/shims/seals/etc. Master kit and one additive gm and three quarts of gear lube. Breakin is a few heat cycles. Prior to getting into it extremely hard......check leaks and double check torque specs. Be patient with backlash set up to prevent whine and improper meshing.......work safe and good luck.........have a blessed weekend.......captain jim
