U-joint size?
Old Mar 1, 2011 | 02:26 PM
mtperformance's Avatar
Default U-joint size?
What is the factory u-joint size on the pinion side of a 4th gen driveshaft?
Old Mar 1, 2011 | 08:23 PM
Supers's Avatar
Restricted User
3r or saginaw 44r or 5-3147 or 5-795
Old Mar 2, 2011 | 12:50 AM
UHHH its an aluminum factory driveshaft, I was wondering if it a 1330 or 1350?
Old Mar 2, 2011 | 01:12 AM
Oldsmobility85's Avatar
The metric ones are smaller I think. How about going to the parts store and measuring one? I think hes giving you some part numbers to work with.
Old Mar 2, 2011 | 08:22 AM
Deviant LS1's Avatar
It's a 3R. To go from a factory driveshaft to a pinion with a 1330/1350 or vice versa you need to use a conversion ujoint.
Old Mar 2, 2011 | 08:33 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Supershafts already answered your question - the joint is a Saginaw 3R. NOT a 1330, and certainly not a 1350.
Old Mar 2, 2011 | 11:34 AM
Ok I was just wondering what combo joint I would need.
Old Mar 2, 2011 | 11:50 AM
MeentSS02's Avatar
What are you trying to hook the factory driveshaft to? A 1330 yoke, 1350? You never specified.
Old Mar 2, 2011 | 05:20 PM
Supers's Avatar
Restricted User
Why not ask what it is you really want to know....
This beating around the bush isn't going to get a better or different answer.
Even the AL aam factory shaft uses the 3r/s44 series.
If you are trying to go from 3r in the shaft to 1350 in the end yoke, for a aftermarket diff you would be looking for a neapco 2-1153
3r to 1330 will be joints 5-212 (g) or 5-794 (ng)
Old Mar 2, 2011 | 06:18 PM
MeentSS02's Avatar
I think he asked that question because he didn't understand your answer. After all, for the longest time, I thought the stock joint was a 1310...it took talking to a driveshaft shop and me taking measurements to figure out it was something different.
Old Mar 2, 2011 | 06:45 PM
Supers's Avatar
Restricted User
You would have been right w/1310 had you had a earlier camaro
Old Mar 3, 2011 | 02:45 AM
I am putting a 8.8 in my 97 TA and the 8.8 has a 1350 yoke on it.
If I can get away with using a combination joint and the factory driveshaft that would be cool.
Old Mar 3, 2011 | 03:53 AM
Thanks supershafts your like a driveline text book man.
Old Mar 3, 2011 | 11:56 PM
Supers's Avatar
Restricted User
Then you want the neapco 2-1153
This is what i do, glad to make someones life a little easier
Old Mar 4, 2011 | 10:40 AM
01ssreda4's Avatar
Not knowing better, and taking advice from this website, I installed a 1310/1350 conversion u-joint from a stock steel drive-shaft to a Moser 9 inch. Worked fine.
