Carrier Question/ Major Help
Old Mar 3, 2011 | 11:01 PM
hsnqb's Avatar
Default Carrier Question/ Major Help
I have a 94 trans am and my posi is going, or so I think. It starts grabbing when I turn if its hot, but I did add some additive and it mostly stopped...anyways.. I have a 2 series carrier with 273s and I want to go to 373s. I know that the gears will fit in but what happens if my posi is bad or ends up going after i put the new gears in? I called the shop and the guy was a jackass so im looking for major advice. Finally, is the carrier the posi traction part of the rear end? for instance if my posi goes with my new 373s do i have to get a 3 series carrier or what!?!? PLEASE HELPPP
Old Mar 4, 2011 | 01:47 AM
Oldsmobility85's Avatar
Im not quite following what you are saying. Is the posi not spinning both tire on a corner? Additive is designed to let clutchs slip slightly so it is more comfortable to the driver. You can always buy a clutch pack for your carrier and rebuild it.
Old Mar 4, 2011 | 10:07 AM
hsnqb's Avatar
what im trying to figure out is, is the carrier the posi portion or the rear end?
Old Mar 4, 2011 | 10:46 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
the carrier is the posi part,the ring gear is bolted onto the carrier,that assembly is held/positioned in the rearend housing by 2 main caps,the axle splines slide in the carrier,
Old Mar 4, 2011 | 11:07 AM
justin hover's Avatar
I can answer the part where you said "for instance if my posi goes with my new 373s do i have to get a 3 series carrier or what"....no
