fastest 10bolt auto
what is the approximate power range that kills them and how fast has some one gone using the 10 bolt?
if i plan on doing a 3000-3600 stall is it worth putting a set of 3.73's and better LSD in 10 bolt?
I feel like the bigger the tire and the less shock you put them through the better.
Drive them sensible and foot break them hard instead of flashing the converter real hard and it should last a while. I sprayed mine out of the hole one time at the track and that was the final straw. But my car makes around 600 flywheel and has a 175 plate kit on it though.
Yeah...see for me...It's not about the track, ets, none of that stuff...It's all about the quality of my dd...and for me, I have 2 girls I have to pick up from school, and lots of city driving....so imao...the 2:73s are absoulutly not good for this...The gear swap gives me (and the girls) a great sotp feeling that truly makes dd fun..I'm hardly ever over 55mph, so I'd alway's reccomend them over 273s...
and for the op....don't spend /waste your time trying to figure out when your 10 bolt will take a ****...I did this and it got me nowhere...some run 10s,11s and some take off with slicks for the FIRST time and blow their rear end...just don't completely neglect your suspension and you'll be fine...If you go to the track everyweekend, I'm sure your asking for trouble though.
