410 help!
This is our first time installing 410 gears in our 2001 z28 Camaro. He put them in and there was a slight whining, so he took them out to get them realigned and for some reason, he says they arent lining up right at all.
Does anyone have any suggestions/helpful info...it would be much appreciated!
Emilie
.008 to .010. may need less or more shims to accomplish that. If it is in spec then the pinion could not be installed correctly
Your next step is to go to Randysringandpinion.com and in the downloads section download the Yukon gears instalation instructions. Read them thoroughly and understand how the setup goes.
Also if hes reusing all the factory shims and spacers instead of buying a install kit hes asking for trouble. There are no one size fits all shims and a install kit or just a variety of pinion and side shims with something to mark a wear pattern with is most necessary.
Good luck and let us know how the car does at the track.
1. Micrometer (measuring shims)
2. Dial indicator (measuring backlash)
3. Inch pound torque meter (measuring pre-load)
4. Torque wrench (measuring torque)
6. Press or bearing press
A. If you don't have them, the cost of the labor for a professional to do it will be cheaper than buying those tools
B. If you do have them, you can take a shot
As you are witnessing i recommend A
Is it whining on accel or decel, or is it whining EVERYWHERE ?
