harmonics from rear area of car?
After my moser 9 install, and new shocks, and springs. Adj torque arm. From the rear, When cruising above70mph. My ws6 hums and has a distinct repeating noise. It sounds like hum......hum......hum...... hum...... and the faster I go, the louder it gets. At 80 mph, you cannot hear the radio that well....... so any ideas on where to start? Thanks stunna
LS1Tech Premium Sponsor
it's called "driveline droan". Most likely causes are from and inbalanced driveshaft, excessive ring and pinion runout, and driveline/pinion angle out of spec or improperly setup. The pinion on a 9" rearend is located lower from center than a 10 bolt so your trans crossmember may need shimmed to get the driveline angles setup properly along with the pinion angle... they work together and the two angles must be the same(but opposite)to cancel out vibes.
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
