Shortened axles...
Old Mar 27, 2011 | 07:56 PM
bluey2kz28's Avatar
Default Shortened axles...
What advantages and disadvantages are there to installing a shortened axle into a fourth gen F-body? When I say narrowed I mean only 2 inches at most without having to minitub it and the wheels will be offset to fit 11 inch wide wheels so that they do NOT stick out past the fender. Your serious input is much appreciated.
Thanks,
Old Mar 29, 2011 | 05:16 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The rear would weigh slightly less being narrowed, and will allow a wider rim without have to run an offset (opposite of a deep-dish) wheel. The only problem that I see is it wouldn't allow you to run stock wheels should you ever need to. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 29, 2011 | 11:00 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
Thanks,
The most common narrow is -3 per side. There is no need for mini-tub even at -4.5 per side even... its all just difference in wheel backspacing. We can usually adjust the housing width to accommodate any set of wheels, or we can get you into a matched rearend and wheel package from Weld, Billet Specialties, or Holeshot.
The thing with 11" wheels and keeping them inside the fender lip is the bumpstop clearance. Most people are just removing the bumpstop and mount with a sawzall and get plenty of space to make it work.
Give us a call... we have a package special on a rearend and a set of Billet Specialties Street Lite 17" wheels right now.
