additive or not?
Old Mar 31, 2011 | 04:08 PM
keith102371's Avatar
Default additive or not?
I just did axle bearing and seals in my 99 ss 10 bolt, do I need to add the posi additive or is that just for Auburn carriers, which does not have right?
Old Mar 31, 2011 | 10:51 PM
poltergeist 02's Avatar
if you have a torsen carrier then you don't need it. if you have an auburn you do need it. you should have a torsen if the rear is stock. i'm pretty sure that gm switched units between 98-99. if it is an early 99 build date you may want to take a look inside just to be sure.
