Leaking problem on passenger side...
Old Apr 3, 2011 | 02:24 PM
BlkBird2000's Avatar
Default Leaking problem on passenger side...
I have a moser 9". I used the bearings that they sent me. My passenger side is leaking pretty bad. Covers my caliper, rotor, and inside of wheel. It's not leaking on the outer part of the bearing where the small black seal is, its in the middle of the bearing. I'm not sure how it's leaking right there but it is. I can't use any kind of silicone because the axle spins where it is leaking. Do I need to get a new bearing or something?
I highlighted in red where it's leaking at. These are not my bearings but I have the same ones.
Old Apr 3, 2011 | 07:22 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Did you fill the gear oil to the bottom of the fill hole located on the driver side of the center section? It sounds like you may have to much gear lube in there. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 3, 2011 | 11:52 PM
Why does my passenger side leak and not my drivers side? Seems like they would both leak if I put a lot in, which I did. Probably 3-4 quarts.
Old Apr 4, 2011 | 05:39 AM
LS1Tech Sponsor
Our road typically are crowned to drain water off to the curbs. You should of filled your rear to the bottom of the fill hole, shown in the picture here. Bob
__________________
Old Apr 4, 2011 | 06:07 AM
same o'j's Avatar
Default 9' bearing
what the part# of these bearing and press ring ?
and what size of the housing tube 3" or 3"1/5
Old Apr 4, 2011 | 05:46 PM
3" but I don't have any part numbers.
I'll drain the fluid out until the correct amount is left in it and see how it does.
Old Apr 5, 2011 | 05:49 AM
LS1Tech Sponsor
Question
That should take care of it for you. I take it you filled it up through the vent hole on top of the driver side axle? Bob
__________________
Old Apr 5, 2011 | 09:50 AM
There is actually a nice shiney cap on the back side of the rear end. About the size of a half dollar. I filled it up using that. I wasn't aware using too much could make it leak.
Old Apr 5, 2011 | 09:56 AM
LS1Tech Sponsor
Thumbs up
Gotcha, you ordered yours with the optional fill plug. You still have to remove the side plug and fill it to where it just starts to trickle out of the side plug. Let me know if it takes care of your oil leak. Thanks. Bob
__________________
Old Aug 17, 2011 | 10:17 AM
Alright draining the oil out to the level it should be did not fix the problem. Where the red line is, is there a seal there that keeps the oil from coming out? Should I replace the bearing? Thanks for any help.
BTW, I do not have an inner seal on either side. But only the pass side leaks.
Old Aug 17, 2011 | 02:23 PM
LS1Tech Sponsor
I'd replace the bearing and add an inner seal. Here are the part numbers from Napa. Bob
- Napa Replacement part numbers for nine inch wheel bearings and seals.
Bearing: 88128-R
Inside Seal: 15142
__________________
Old Aug 20, 2011 | 10:55 AM
Alright I bought the parts. This napa bearing does not have the rubber seal on it like the one I got from moser. I suppose just use some silicone around the outside of the bearing when I put it in?
Which way do I slide the inner seal on?
Old Aug 22, 2011 | 10:19 PM
Giddswat's Avatar
Any updates with this? I am having the same issue.
