LT1 axle to LS1 axle difference?
Old Apr 4, 2011 | 08:38 AM
roughneck427's Avatar
Default LT1 axle to LS1 axle difference?
I see moser says the same axle for 93-02 but i see other axle manufacturers give a break for 93-97 to 98-02. My car is no trac control. Alloy USA has a nice kit but not sure of fitment. Any info would be great
Old Apr 4, 2011 | 02:42 PM
Oldsmobility85's Avatar
They have a slight flange width difference of about an eighth of an inch. They calipers will slide enough to compensate for that if need be but if you are buying a new set why cant you just order them for what you already have as far as brakes go??
Old Apr 4, 2011 | 04:13 PM
Deviant LS1's Avatar
Does the kit come with backing plates? The backing plates are different between LT1 and LS1 years because of the brake calipers, rotors and e-brake.
Old Apr 4, 2011 | 04:53 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Moser does not supply the axles or rears with the brake backing plates, you reuse the old backing plates. 1/8" shims are used on the axles for '93-'97 F Body's. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
