gear install gone bad?
Old Apr 11, 2011 | 01:11 AM
zooguy's Avatar
Default gear install gone bad?
got motive 3.73's 287 miles ago have done 9-12 heat cycles and the gears today started to whine really bad on the way home from work (8 miles). the last half i noticed it getting louder as i gave it gas and the speed increased and the last 2 miles it was loud as i was braking and got under 10 mph ...
i know gears can whine but is that also a sign that they are about to take a dump?
i have followed all the rules for the proper break in process keep it under 50mph, dont hold a constant speed for very long, stop every 15-20 miles to let gears cool for 30 - 45 min before continuing, and NO WOT ... and i know that i need to do this for 500 miles
Old Apr 11, 2011 | 01:14 AM
Big Al's Avatar
I'd answer this but, it's not good
Who set up the gears?
Al
Old Apr 11, 2011 | 01:20 AM
PitchblackC3's Avatar
Formerly 99-2door-08/30/2010
If you are hearing whining, it's only gonna get worse.
Old Apr 11, 2011 | 01:37 AM
zooguy's Avatar
i am okay with gear whine ... i just am nervous that they are going to dump on me stranding me with out a car to get to work
gears installed by Bo Woody @ APS automotive
Old Apr 11, 2011 | 02:20 AM
SS SLP2's Avatar
from what you say ,they ARE going to need be reset/replaced or you WILL get stranded
Johnny
Old Apr 11, 2011 | 03:34 AM
zooguy's Avatar
i just wish i knew how long
Old Apr 11, 2011 | 03:01 PM
Big Al's Avatar
If you have noise in less than 300 miles, don't expect it to live very long. Who set up the gears?
Al
Old Apr 12, 2011 | 03:08 AM
zooguy's Avatar
Old Apr 12, 2011 | 11:26 AM
Big Al's Avatar
I'd be talking to him. Get it back to him ASAP.
Al
Old Apr 12, 2011 | 12:34 PM
zooguy's Avatar
i stopped driving it after it got noisy and i am looking to get a trailer or flatbed truck to get it over there
Old Apr 12, 2011 | 04:34 PM
justin hover's Avatar
yeah...that's your best bet....I got my motives 3:73s a month ago and was just waiting to see what all this gear whine was about...still don't know what noise it makes ask him what the pinion depth what set at...mine was .008
Old Apr 13, 2011 | 08:15 PM
zooguy's Avatar
took in the car and the "coast side/reverse" is perfect. the yellow grease gets wiped from the center of the teeth just like it should. but going the other way the "drive side" wipes the very edge of the ring gear in the center/ inside ... can the drive side be centered up some and the coast side not change?
if not
can the drive side be centered to wipe as it should and the coast side be pushed to the outer edges of the ring gear?
noise is going to happen i know but what will make the gears last longer and not eat themselfs up?
Old Apr 14, 2011 | 07:18 PM
zooguy's Avatar
can the gear gods offer any advice?
Old Apr 14, 2011 | 07:38 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
from a GM manual
Is the 'toe contact' your situation ?
Old Apr 14, 2011 | 09:52 PM
zooguy's Avatar
on the drive side yes ... more than in the pic shown ... odd thing is the coast side it is just right
so what does that mean more backlash?
Old Apr 15, 2011 | 01:45 AM
Big Al's Avatar
Find an older Ford truck, or full size car shop manual. They have the best pictures for what the patterns should look like. You need to get the coast AND drive side right. Sometimes the carrier pre-load is set too loose and the ring gear will move away from the pinion under acceleration. Something to look for.
Read this:
http://www.ford-trucks.com/article/i...ear_Setup.html
BTW: Once the gears are noisy, they are never going to be quiet. If you drag your finger nail across the tooth you'll feel tiny ridges. That's what you're hearing.
Al
Old Apr 15, 2011 | 08:14 PM
bww3588's Avatar
not entirely true. ive always found, if your gears start to whine under 500 miles, it can usuallly be corrected as long as you dont keep driving it.
Old Apr 16, 2011 | 03:23 AM
01ssreda4's Avatar
My Motive 3.73s have a slight whine, have since the second time I took them out and hammered on them from a 40 roll. It has never gotten worse. Just a slight whine. If it was getting worse as I drove I think I would be a little nervous.
