Rear end clunk
Old Apr 12, 2011 | 08:20 PM
cfallsguy's Avatar
Default Rear end clunk
Well lately I started hearing and feeling a clunking noise from what I believe is the rear end. The problem doesn't arise until I get to about 3rd or 4th gear and when it shifts the rpm's drop to about 1500 and stay there. When I try to accelerate the rpm's rise slightly then come right back down to 1500 and the rear will start clunking and the harder I try to accelerate the more it clunks. Like said, it doesn't happen when trying to accelerate at lower speeds, as far as I know, just when it hits a certain gear. I was wondering if the pinion or ring gears were shot and if so or any other suggestions you guys may have. It's an auto by the way.
Thanks
Old Apr 13, 2011 | 05:58 AM
Scoobysnacks's Avatar
Check your universal joints...
Old Apr 13, 2011 | 06:04 AM
jsteele90's Avatar
^^ check u joints, trans and torque arm mounts, and the bolts for the torque arm that mount to the rear end
