Torque arm question
Old Apr 17, 2011 | 07:43 PM
kilrbecars1's Avatar
Default Torque arm question
I just bought a new 9" for my 2000 TA, what is the trick to getting the new BMR torque arm to mount up? I cant get this thing to line up ( the rear holes) any help please!!!
Old Apr 17, 2011 | 08:00 PM
89 formula350's Avatar
what 9" is it? (who makes it)
Old Apr 17, 2011 | 09:27 PM
mlatorre's Avatar
Try placing the assembly on a jack. Install the tourque arm to the unit first, then complete the assembly at all other connections of the diff.
Good luck,
mlatorre
Old Apr 18, 2011 | 03:41 AM
Brute speed
Old Apr 18, 2011 | 05:11 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
It is a Moser 9 inch, and I recommend trial fitting the torque arm to the rear prior to installing the rear into the car.
Here's some pic's of torque arms installed, hopefully you might see something that will help you out. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 19, 2011 | 03:51 AM
From the way it looks, I may have to do some drilling. This is what I thought, just wasn't sure. Thanks Bob
Old Apr 19, 2011 | 04:32 AM
LS1Tech Sponsor
No, you shouldn't have to do any drilling. Sometimes you have to do a little grinding on the bracket though. Give me a call when you get a chance.
Thanks. Bob
__________________
Old Apr 24, 2011 | 09:17 PM
Texhotrod593's Avatar
can you use the stock thru bolts for the aftermarket 9inch and torque arm?
Old Apr 24, 2011 | 09:59 PM
SS SLP2's Avatar
^^^ yep
OP, on my 9" the housing would roll up which caused a problem connecting the TA just had to roll it down to make connection not sure if this is your problem or if the bracket is tight
Johnny
