driveshaft question
Old Apr 28, 2011 | 02:05 PM
layz's Avatar
Default driveshaft question
Is it possible to install a driveshaft wrong.
Old Apr 28, 2011 | 02:19 PM
Parsticks's Avatar
I don't see how you can. If you can slide the yoke in and bolt it up should be no issue.
Jim
Old Apr 28, 2011 | 05:57 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You can tighten the u bolts or retaining straps too tight, which can distort the u joint caps and damage the needle bearings. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 29, 2011 | 07:52 AM
Supers's Avatar
Restricted User
You could install a shaft with the wrong size joint and just get it in there.
You can over tighten the U-bolts and distort the cap causing the joint to wear and not oscillate on 1 axis, and/or even break needles.
Old May 3, 2011 | 08:41 PM
Driveshaft Shop's Avatar
Being no pinion yoke is made perfectly there may be no wrong way but one side or the other may be better for balance than the other. We recently did some testing for a NASCAR team and had a few different manufacturers pinion yokes to put up in the balancer with the shafts. you would not believe how many "top" brands are not centered properly......
