Help! How to remove axles on 2000 SS four channel
I am trying to remove the backing plates and parking brakes from a 3.23 Torsen 4 channel. To do this I have to remove the axles. I have removed the rear diff cover and drained the oil. Instructions say to push the axles inward to pull the C clips. I tried, but the axles don't move. I also don't see where the C Clips are located. Pictures or diagrams would be a great help. I obviously am very new to this.
Thanks in advance for your help
the small diameter long screw running horizontally in pic,hex size,I think,is 5/16. Remove that screw and the 'block' that it's screwed thru will pull out. the end of the axles and c-clips will be visible in the space that block occupied.
Make sure the pin is removed but I also found issues with the ABS sensors mounted on the backing plates. These could give you a problem also, remove to move the axles in just a lil more.. Oh and another issue I have found on a vehicle b4 is the rear was rebuild years before and the used axle saver bearing which are a tad wider pulling the axle out a little. The guy must of hammer the c-clips in and the will NOT come out. lol Hopefully you will not have this issue! Good luck bro have fun
