upgrading to 3.73 gears!
Old May 7, 2011 | 01:54 AM
black_phoenix's Avatar
Default upgrading to 3.73 gears!
I currently have a 2.73 geared 98 trans am A4 and thinking of buying motive 3.73 gears from ws6 store before i install my stall converter and headers.
I just need a little clarification on what gears to buy:
1) these should be 2 series for 7.5" differential, correct?
2) Would I have to buy an istall kit for them as well?
Never had a geared car, so i thought i would ask these questions before i make a move...
Thanx for the feedback
Old May 7, 2011 | 02:05 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Yes,2 series 'thick' set for a 7.5 differential.
What year is the car ?
You don't have to buy a install kit,BUT very highly recommended,because of the crush sleeve,bearings,pinion & carrier shims,pinion/yoke seal & nut.
This should have posted in the 'gears & axles' forum.
Old May 7, 2011 | 02:18 AM
thanx, and its a 1998 trans am
Old May 7, 2011 | 02:41 AM
3.73s' and a stall are probably the best combination to do.
What size stall are you thinking ?
Computor will have to be 'tuned' to correct speedo and possibly shift points as shift points are MPH based,not RPM based.
Old May 7, 2011 | 03:08 AM
01ssreda4's Avatar
I like my Motive 3.73s. I would highly recommend a Ratech full bearing/race rebuild kit. Do it all while you have it apart. I believe they run about $100 with no axle bearings/seals or $140 with.
Old May 7, 2011 | 11:39 AM
Thanx guys! I will buy an install kit as well. I have a 3400 vigilante and a tranny cooler awaiting install as well
Old May 8, 2011 | 10:45 AM
BIG_MIKE2005's Avatar
Even cheaper my friend, here is a link. The kit without the axle bearings & stuff is only $78+shipping
http://www.ws6project.com/user_stor/...feae8fdfcd1873
Old May 8, 2011 | 11:12 AM
Tobias05's Avatar
don't forget to grab a solid pinion spacer. lil extra insurance.
Old May 9, 2011 | 01:58 AM
thanx for the link gears are def in the works now!
