8.8 inch
Old May 8, 2011 | 01:44 PM
Camaroking1996's Avatar
Default 8.8 inch
What would it take to bolt up an 8.8 mustang rear end up to an lt1 camaro?
Old May 9, 2011 | 07:15 PM
L92 fox's Avatar
Use the search.....I've always wanted to post that....it feels good
Old May 9, 2011 | 08:18 PM
theskitztikwon's Avatar
You know what sux about the search feature? When I do a search half the time all I find at first is other people telling other people to do a search, but honestly do a search and sift trough all the search ***** and you will find what your looking for just make sure you do the advanced search. Doing an 8.8 is no small task FYI.
Old May 10, 2011 | 02:40 PM
fastsspr's Avatar
It takes to find a 8.8 donor to use the housing . Is many ways to do it you can weld the camaro bracket to the fox housing or you can use the 8.8 pumpkin with camaro tunnels.
I stater build one for my camaro you can find more info in my posts. You need to do some fabrication to but it is possible.
Old May 10, 2011 | 05:32 PM
wfritts911's Avatar
Personally the search function on this site is questionable at best. Use google and search then show results from LS1tech instead, that works a million times better. But in short its either swap brackets or swap tubes. But like said above its no easy task, and should not be attempted unless you are confident in what your doing.
-Will
