help choosing wheel studs for 9
Old May 24, 2011 | 11:03 PM
LS1_Sean's Avatar
Default help choosing wheel studs for 9
Trying to decide between 12x1.5 or 12x2.5 I'm currently running the SS wheels and I was concerned the longer studs wouldn't clear the lug nut cap.
Old May 25, 2011 | 06:14 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'd go with the short 12 wheel studs. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 25, 2011 | 10:04 AM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
If you are buying 9" axles and are choosing wheels studs I would recommend going to 1/2, they are generally 30% stronger depending on the manufacture and your stock wheels will work with them.
Old May 25, 2011 | 02:23 PM
LS1_Sean's Avatar
Which ones will work with stock wheels?
Old May 25, 2011 | 03:31 PM
LS1Tech Sponsor
Question
I can't say I've ever tried the 1/2 studs with the stock wheels, the 1/2 studs do work with all of the aftermarket wheels that I have tried them with. Bob
__________________
Old May 25, 2011 | 04:23 PM
They both will, they are virtually the same size. We very rarely sell 12mm studs with our rear ends or if we do we set our customers up with both 12mm and 1/2 holes that way you can do either or and is worth it for the extra $15 it cost.
We do the same for customers wanting to run 1/2 now and possibly 5/8 studs at a later date. Well worth it and much cheaper than trying to do it at a later date.
Old May 26, 2011 | 06:26 PM
LS1_Sean's Avatar
ok thanks for the info. is there a 1/2 lugnut that will work with the plastic caps? not really a big deal but im just curious.
Old May 27, 2011 | 05:10 PM
oldguy99Z's Avatar
Yes you can get OEM style external thread lug nuts for 1/2" studs.I just got a 12 bolt with 1/2" studs and did this.I couldn't find them at any local parts stores so found some here- E Z Accessary.com.They have all sorts of lug nuts and also plastic caps.The larger lug nuts take the larger size plastic caps like the GM trucks that have 14mm studs take. BTW I got the longer studs and the large caps fit on over them.You have to really look at the front and back wheels to notice the larger caps.Hope this helps.
