HELP: Moser 9inch gasket problem
I'm thinking I was sent the wrong one, no matter which way i try to line it up it will not lay flat.
Can i use RTV instead of the moser supplied gasket
Also the instructions say use gear oil with no Limited slip additive i couldn't find any at my local autozone without it. Suggestions.
this is the one that was sent:
http://www.jegs.com/i/Fel-Pro/375/2301/10002/-1
and this is the one appears that it would fit:
http://www.jegs.com/i/Fel-Pro/375/2302/10002/-1
Rearend for reference:
