Is total abs delete necessary?
Old Jun 21, 2011 | 09:40 PM
pHEnomIC's Avatar
Default Is total abs delete necessary?
Say I got a rearend without abs sensors.
Can i still just bolt up the brakes and go? (obviously abs won't work)
Eventually i will get a delete unit but I want to just do the rear now.
Old Jun 21, 2011 | 09:52 PM
Emulsifide's Avatar
Your brakes will be fine sans the sensors. ABS just won't kick in and you'll trip the ABS light on your cluster.
Old Jun 21, 2011 | 10:58 PM
01ssreda4's Avatar
^^He's right. You will likely get a couple of lights come on.
Old Jun 21, 2011 | 11:06 PM
gofastwclass's Avatar
Mine was acting weird after a rear end swap so I pulled the wires going to the front sensors (unplugs at both ends) to keep the front brakes from going anti-lock at random times.
Old Jun 22, 2011 | 09:12 AM
onfire's Avatar
Coal Mining Director
I would pull all of the abs fuses for safety...
