best way to fill rearend with t/a cover
Old 07-12-2011, 07:38 AM
vbls's Avatar
Default best way to fill rearend with t/a cover
i bought a used t/a cover off of here, i was wondering the best way to fill the fluid, do i go by amount i add or until fluid starts coming out the hole? just want it to be right
thanks
Old 07-12-2011, 06:12 PM
OldCobraGuy's Avatar
I always want the oil at the level of the bottom of the access hole, or down about a quarter of an inch. You can fill these through that hole until it is level with the bottom of the hole, or fill it through the ABS sensor (3 channel) hole until it runs out the access hole on the side. Whatever works easiest for you.
Old 07-12-2011, 09:00 PM
killagt's Avatar
man u lucky, I been look for that TA cover for month.
Old 07-13-2011, 08:05 AM
vbls's Avatar
About how much fluid is that
Old 07-13-2011, 08:49 AM
I also just realized what cover you have. The top hole in the cover is for filling purposes. You still use the side hole as a level measurement. As to how much fluid, you will just have to fill it and see as I don't know what changes (if any) to capacity that cover makes. I would bet that two bottles will be more than enough.
Old 07-14-2011, 03:26 PM
vbls's Avatar
so i fill it in the top hole in the cover until it starts to pour out the side hole???
Old 07-14-2011, 04:19 PM
killagt's Avatar
yes, 2 quart is plenty.
