Major 10 bolt Issues please help!!
Old Jul 15, 2011 | 03:14 PM
fbodyman1026's Avatar
Default Major 10 bolt Issues please help!!
So lately i've been noticing like some sort up a shake from 50-70mph from the rear end. It is really hard to describe but i know something is up because i can feel the rattling in my legs and can see the passenger seat shake. I haven't been hard on the car at all recently due to the shake so i replaced my u joints and had the driveshaft rebalanced but that didn't fix the problem at all. So today i said screw it and went WOT at 25ish in first and the left rear tire had like major wheel hop/ spin issues and right before it shifted it clunked SO f****in hard i thought it blew up lol. Like someone hit the bottom of the bar with a sledge hammer. So any ideas it has 74k on it??? Also the POS has so much seepage you cant even see anything metal near it.
Thanks
Old Jul 15, 2011 | 06:15 PM
V68Sweep's Avatar
Well...it's probably busted or damaged somehow. You should fix that leakage anyways, so while you're taking the cover off inspect the gears to see if they've cracked.
I'm just waiting for the day my 10 bolt takes a dirt nap
Old Jul 15, 2011 | 09:15 PM
anyone else have some input? Im really confused because i just went wot from 20 again and it hooked like normal.
Old Jul 15, 2011 | 10:04 PM
Platinum WS6's Avatar
sounds like your posi just said good bye....I have replaced mine a couple times. You will know if its your posi if it is popping when turning especially. Probably broke a tooth or two . Take the cover off and inspect it
Old Jul 16, 2011 | 11:56 AM
i have been noticing a clicking/popping when turning slowly. I didnt think it would be coming from my posi though. I will take the cover off and check soon....
Old Jul 16, 2011 | 12:59 PM
poltergeist 02's Avatar
you said it sounded like something hitting the bottom of the car? maybe a broken trans mount? or even a bad torque arm bushing?
Old Jul 16, 2011 | 02:23 PM
yeah it only happened twice and never since but i should still look into that. I've been thinkin about just have everything in the rear end replaced. I wil have to look into those mounts though.
Old Jul 17, 2011 | 09:46 PM
hevymetalg's Avatar
Dude mine was doing the exact same thing and it just gets worse. It's def the posi going.
Old Jul 18, 2011 | 03:25 PM
so i havent had time o inspect it yet but incase its shot what posi do you guys recommend going with? Car is full bolt ons with a stall being added soon. ANything else i should replace during the meantime also?
