Pinion angle, please verify me
Old Jul 16, 2011 | 03:05 PM
98sscammed's Avatar
Default Pinion angle, please verify me
I have been messing with this for so long and confused myself even more. The driveshaft is sloping downward towards the rear and is at 1.5* and the pinion is set downward towards the front of the car at .5*. Since both of those angle are negative the pinion angle is at -2*. Am I correct? I am still getting vibrations when I am driving and are noticeable when on the highway above 65. I have a t56, a brand new drive shaft from Strange and a new s60. Please help before I pull all my hair out.
Old Jul 16, 2011 | 03:49 PM
99MUSTANG5.3L's Avatar
No, if your pinion angles down at -.5* that's your pinion angle. I set my drive shaft angle at -2*. My motor is pretty much at 0* and so is the pinion angle. So far I've been to 105mph and no vibrations.
Old Jul 16, 2011 | 04:10 PM
99SSJarhead's Avatar
I'm a bit confused. You say your "pinion" is set at -.5*. Do you mean the part of the car your torque arm mounts is at -.5?
If so, then that + the -1.5* of your drive shaft would be -.2 which is ok. You could also try lowering it to -1 and see if that helps.
If that is correct it may well do to start looking for other culprits for the vibration.
Old Jul 16, 2011 | 04:35 PM
98sscammed's Avatar
I just took my driveshaft out and the tailshaft is pointing downward at 3* and the pinion is downward at .8 degrees. If I am reading everything correctly that is (-3)+(-0.8)= -3.8. So should the pinion be pointing up at +1 to equal -2. That is ignoring the driveshaft. Driveshaft is at -1.2 now and the actual pinion (or flat part of the torque arm mount) is at -.8* which equals -2. I dont know which is correct
Old Jul 16, 2011 | 04:40 PM
The second as far as pinion angle is concerned.
Old Jul 16, 2011 | 10:18 PM
98sscammed's Avatar
I just noticed the torque arm was pushed against the tunnel so I lowered the arm down a bolt and re-adjusted the angle. Hopefully that fixed all the problems.
Old Jul 16, 2011 | 10:34 PM
98sscammed's Avatar
99SSJarhead- did you mean -2 on you first post. Otherwise where did you get -.2?
Old Jul 17, 2011 | 12:43 AM
yeah... not sure where the decimal came in
Old Jul 17, 2011 | 09:38 AM
onfire's Avatar
Coal Mining Director
If your tailshaft is pointing down 3 degrees, the pinion should point up 1 degree so they will be in phase under power.
Old Jul 17, 2011 | 07:27 PM
25thhawk's Avatar
If you do it that way, you will have a wicked vibration under no throttle and decel conditions. You should set the chassis of the car level (0 degrees) then set the rear with the pinion pointing downward at 2 degrees. Setting it up without leveling the chassis and trying to do the math gets confusing and most times ends up with it getting set wrong. I had a vibration problem with my s60 install. Ended up being a driveshaft that was too short. I tried adjusting pinion angle a few times to make it better, but it wouldnt work. Once I put the new driveshaft in, I still had a slight vibration until I readjusted it this way. I was told to do it this way be Denny's driveshaft. So I would trust them as a source.
Good luck with it.
Ryan
Old Jul 17, 2011 | 10:17 PM
98sscammed's Avatar
Thanks for the input. I tried the one degree up and if felt great until I got 70+. I will try the 2* down. The drive shaft is brand new from Strange. If this next adjustment does not do it I will get the driveshaft looked at.
Old Jul 17, 2011 | 10:24 PM
98sscammed's Avatar
When you say level the chassis, my car has a 3/4 inch rake and I have been accounting for this and leveling the car at ride height and figured out my garbage has a 1/8 downward slope and added that in too. Should I just leveling the chassis and not messing with ride height.
Old Jul 18, 2011 | 06:39 AM
25thhawk's Avatar
The rake of the car should not matter. You are setting the pinion angle in relation to the chassis and motor. Since the motor is typically 2-3 degree down toward the rear, it is easier to just level the chassis and then set the pinion angle. If it were a lifted pickup truck, maybe it would be done differently, but Denny's told me this is how it should be done for these cars. FWIW, my strange driveshaft was like 3/4" short which caused a bad vibration in my car. If you still have a vibration after setting the pinion angle, I would look at the driveshaft first.
Ryan
Old Jul 18, 2011 | 10:51 AM
onfire's Avatar
http://www.rosslertrans.com/Pinion%20angle.htm
If your angle measurements are correct, you have something else causing the vibration. I've been 174mph with the above method with zero vibration.
Old Jul 19, 2011 | 10:58 PM
98sscammed's Avatar
I called the guys at MWC yesterday and he suggested that I stick with driveshaft/pinion method and put the pinion angle at -1.5 and to also rotate the driveshaft 180* and I am not sure which one did it but no more vibrations. I hope that it stays that way. And only 30 more miles until I clean the diff out and get to enjoy the car.
