slip yoke question??
I haven't had time to drive the car much due to the weather, but i did took it out the other day for some heat cycles and i noticed that if i go into a complete stop leaving the car in gear with the clutch pressed, it will give me hell to get it out of gear. does this had to do with the slip joke not going all the way in or being too far out? thanks in advance for the help
To tell if your yoke is too far into the trans see If your yoke will slide into the trans enough that you can drop the rear universial down and clear the rear end yoke with the suspension at normal ride height, if so you should be OK.
