Need help with driveshaft measurements
Hey guys I'm a little confused on finding the right driveshaft for my car. I have a '85 camaro with a ls1/th400/10 bolt. Since my old driveline was too short I measured from the pinion yoke to the transmission output shaft and got 46 3/4"
Now I've seen a few camaro driveshafts for sale that said they are that same 46 3/4" length from "center to center". I'm curious if that length would work, because if thats the measurement from center to center of the ds, don't I have to factor in the extra length of the transmission yoke to go in?
Sorry if it sounds kind of confusing. Basically, if my measurement from the pinion yoke to tranny output shaft is the same as that driveline from center to center, would it work?
LS1Tech Sponsor
http://shop.brutespeed.com/PST-3-1-2...Driveshaft.htm
The best method to make sure you get the right length is to go by the "x" dimension that is shown in the above link. Make sure the rear tires are in the loaded position when you take your measurement. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
That's the exact guide I used to get my measurement and "x" was the 46 3/4".
I'm just saying I seen a sticking for sale that is the same length from center of u-joint to center and wanted to know if that would work. Im curious if the trans yoke adds additional length and will be a tight squeeze
when i measured mine for the new shafti slid the yoke into the trans where i wanted it to be then measured form the center of the yoke u joint to the face of the pinion....new shaft fit perfect
LS1Tech Sponsor
__________________
