Need help removing pinion bearing stock 10 bolt
Okay, I can't figure out how to get the old pinion bearing out to put the new one in. I have the driveshaft dropped out and the seal off, but can't get the bearing to move. Is there a special tool or trick to getting it out? Trying to avoid dropping and disassembling the rear at all cost. Thanks in advance for any help!
Pinion bearings need bearing pullers and a hydraulic press to remove properly. On a buddy's car, once we had everything out, the only way to remove the stock pinion from the rear itself was a big fuggin hammer!
need to pull out the carrier and use a long punch to knock it out.. i just rebuilt the whole rear end... i took it out and placed it my garage and took my time... good luck
helpfull video..
http://youtu.be/jh25DUyCWY8
helpfull video..
